define the result
Accepted by topic author suffyzull
Hi zull,
in case you just have ranges ending at x.9 values you can use a "round downwards" function to get integers. Smiley Wink
Otherwise you should use Altenbach's suggestion of array threshold function!
Message 11 of 12
(801 Views)
hello and thanks for the lesson,
i have manage to change my programming data to
round to nearest integer and using case stucture.
So, the value of 9.xxx decimal is not a problems
anymore. Thanks for the advice and have a nice
day to all!
regards,
zull azym
UTHM Researcher,
MALAYSIA.
Message 12 of 12
(782 Views)
