degrees to radians
Hi Folks,
I'm surprised that I haven't found a VI to convert degrees to radians.  I see an example in this forum that shows one, but its a screenshot and not the code.
Can anyone point me at that VI?
Roger
Message 1 of 9
(7,705 Views)
You'd have to point to that link so we know what you are talking about.
But if you have degrees, just divide by 180, multiply by pi, then you have radians.
Message 2 of 9
(7,700 Views)
Depending on your application, you can use indcators with units or a simple math transform.
Message Edited by altenbach on 06-01-2009 11:54 AM
Message 3 of 9
(7,687 Views)
You can also convert a pure number to a physcal number, convert to new units, then convert back to a pure number. 😉
Message Edited by altenbach on 06-01-2009 12:01 PM
Message 4 of 9
(7,683 Views)
Neat trick Altenbach!  I could never figure out that convert unit vi, with your example it just clicked!  Thanks!
LV 8.2/8.5/8.6 - WinXP
Message 5 of 9
(7,671 Views)
Thanks for the quick reply!
I guess I'm not the brightest bulb in the universe.  I only see the diagram as a graphic.  where did you get the unit conversion VI?
sorry, for my density,
Roger
Message 6 of 9
(7,652 Views)
Accepted by RogerMontague
I am not sure if I would take the detour over physical units, but it's all there in the palettes:
Make sure to read the help in detail!
Message Edited by altenbach on 06-01-2009 12:54 PM
Message 7 of 9
(7,645 Views)
Ahh,
Thanks to all!
I was sure there had to be a VI to do this.  I didn't want to reinvent one and have another developer call me on it.  Thanks for helping me do my homework in advance!
Roger
Message 8 of 9
(7,635 Views)
Also, before you start using units, you should familiarize yourself with some of the details, because it can be somewhat confusing.
A good read is this old thread. (To see if you really understand, try to predict the result of the VI attached here, see picture). 😄
Message 9 of 9
(7,633 Views)
