delete a repeating element from an array
How do I delete a repeating element from a string array. I know the element but don't know the indices of this element in that array.............
Please help me................
Message 1 of 13
(5,852 Views)
You question is not quite clear. These are three different solutions: select what do you need.
_____________________________________
www.azinterface.net - Interface-based multiple inheritance for LabVIEW OOP
Message 2 of 13
(5,834 Views)
I have a 2d array of strings. There are lots of blank string constants are present in that array. I want to delete all of these blank string constants and make the array smaller with others string data.......
Message 3 of 13
(5,822 Views)
There are many a times the very same question was asked, please make a search before you post. This is one of the method to remove empty elements.
Message 4 of 13
(5,810 Views)
please upload the vi.......
Message 5 of 13
(5,796 Views)
This will not work because the conditional terminal is true when the string is empty, so it will only add empty strings. You need to invert the output of the empty string function.
Also, all the rows of the array need to have the same number of items so some elements will be filled with the default string value: an empty string.
Ben64
Message 6 of 13
(5,789 Views)
Thanks Ben for pointing me out, I missed the Not operator.
Anyway you cannot restrict the array filling with empty strings at the end if the arrays are of different size.
Message 7 of 13
(5,773 Views)
Message 8 of 13
(5,771 Views)
Drag that picture to your block diagram.  It's a snippet.  The code will populate in your vi.
Also, it would have been much quicker to just rewrite the 5 functions they posted than waiting that long for a new post.
Message 9 of 13
(5,755 Views)
actually I donot know how to add the condition in the for loop..i.e. the question mark type thing in that for loop..........please help me............
Message 10 of 13
(5,739 Views)
