delete historical data from a table
What to do to delete historical data from a table.even when i turn of clients,and i re start the server,in the table the last value entered in a client showed up
Message 1 of 12
(5,161 Views)
Dear achfire,
try
Select the Table (in Front Panel) -> Data operation > Empty table, then
Select the Table (in Front Panel) -> Data operation > Make current value default
Cheers,
Note1: you do not need the for-loo named "Maybe data beyond first column". Remove it. The "equal" and "all" will adjust accordingly.
Note2: do not (over-)use local variables. Just wire the i variable of the for-loop to the "NrOrdreSuivant" through the wall of the case-structure.
Message 2 of 12
(5,151 Views)
thanks for the advice
about your solution i already used it,but it doesn't give me any result.the moment i run the Vi i get data in 6eme row(the last data i entered in a client),it doesn't matter which row but one row show up filled with data.
maybe some invoke node or spmething else i don't know,i think it's a shared variable problem
Message 3 of 12
(5,142 Views)
the table is connected to some OPC (?) data source via the shared variable engine. So on startup it will be filled with the last data the shared variable engine has stored for that item…
Message 4 of 12
(5,133 Views)
what to do to avoid that
Message 5 of 12
(5,123 Views)
I never used that feature on my own, but I guess you can read values by direct access to the shared variable engine (SVE).
Then you would also gain access to a timestamp telling you the time the data was created and so you may differ between old and new data…
Message 6 of 12
(5,119 Views)
Your Vi is full of race conditions because of local variable misuse. Fix that first.
Message 7 of 12
(5,101 Views)
Achfire:
I told you about the local variable problem yesterday.  http://forums.ni.com/t5/LabVIEW/check-if-a-row-is-empty-in-a-table-using-shared-variable/m-p/2837632...  How come you haven't fixed that yet?
Message 8 of 12
(5,090 Views)
You also need to stop writing to indicators and their local variables in parallel. Both operations are equivalent so only writing to the terminal is all you need. Obviously you don't fully understand what a local variable is.
Before continuing with this project, you need to complete all LabVIEW tutorials first (e.g. here). Your current state of training is not suitable for what you are trying to do.
Message 9 of 12
(5,082 Views)
thanks;i'll try your advices
unfortunately;i don't have time to check thoses tutorials,because i have to complete the project quickly.it's a race condition Smiley Sad
Message 10 of 12
(5,069 Views)
