deleting a section of data from an ini file (config file)
Hi
I have a config file (ini file) which has huge data(2000 lines) which contains Sections and keys. I would like to delete a Section and keys
I am using an FGV (functional global variable). I would like to delete part of data programmatically from the file and write it back .
 Delete from array is one solution i know. Is there any best solution to use.
Message 1 of 12
(7,398 Views)
Accepted by mkReddy
If you are using the Config File API that NI gives you, there are the Remove Section VI and Remove Key VI that sound like they do what you want.
Message 2 of 12
(7,383 Views)
Hi Reddy,
with the INI file functions you find a function to delete a key and a second function to delete a section.
What else do you need?
Message 3 of 12
(7,380 Views)
The Sound and Vibration Toolkit has the Configuration File VIs Palette has the following available: Open, Read, Write, Remove, Remove Section, Close, Get Key, Get Section, Not a Config?. If you don't have this toolkit then parse the config file by using base package VIs - Open/Create/Replace, Read from Text File and check for sections and keys. You can put them in whatever container you want (Array,Queue). If you use queues you can flush one of the elements out.
Message 4 of 12
(7,372 Views)
Thank you to all...your suggestions helps me alot..:)
Message 5 of 12
(7,353 Views)
@Regulator wrote:
The Sound and Vibration Toolkit has the Configuration File VIs Palette has the following available...
Actually, you do not need the Sound and Vibration Toolkit to use those VIs.  They are available in the base version of LabVIEW under the File I/O->Configuration File palette.  The SVT just adds another link to those VIs in the palette.
Message 6 of 12
(7,347 Views)
Sweet!
Message 7 of 12
(7,334 Views)
Did we solve your issue?
Message 8 of 12
(7,323 Views)
Hi ,
I have to delete a string in a key... they are tab delimited
[Devices]
Section_Name = " Lpt1 Lpt2 Lpt3 Lpt4 Lpt5 Lpt6"
I would like to delete Lpt3
Get result as
Section_Name = "Lpt1 Lpt2 Lpt4 Lpt5 Lpt6"
How can I get it?
Message 9 of 12
(7,260 Views)
Read the key, change the string as needed, write the key...
Message 10 of 12
(7,249 Views)
