dependency path
Hi everyone, I found a program in this community and when opening it, I always have these warnings in the image below. What could be this error? I even changed the path of the project in the same folder of the driver but it's not working.
Message 1 of 8
(5,745 Views)
The problem is that whoever originally wrote all of your VI's and subVI's used the library they had saved at their desktop rather than the instr.lib folder under LabVIEW.
So the paths were all saved pointing to that location.
You opened it in LabVIEW, it couldn't find it at that \Users\WSI\Desktop directory path, but did find it under LabVIEW\instr.lib.  It is just warning you it updated the links to the new location.
I don't know what you mean exactly by " I even changed the path of the project in the same folder of the driver but it's not working".
The solution is to resave all your VI's so that they are pointing to the correct instr.lib location.  And to go to the original PC and move the library out of User WSI Desktop over to the instr.lib directory so that this doesn't happen again.
Message 2 of 8
(5,736 Views)
Thank you for your response, but It's strange, I did the exact thing as you said and I still have the same problem I moved the project and the drivers in the same library and in the expected path it shows like I have a double folder Agilent but I only have one.
I don't understand.
Message 3 of 8
(5,724 Views)
You must have made some difference when moving them.
Try saving all the VI's again.   Since it is in a library, you will likely have to make sure the library file itself gets saved.
Message 4 of 8
(5,721 Views)
Thank you for your help. I have another question do you have any idea why it shows all these files are affected. These are the drivers files I did only the installation for lcr meter.
Message 5 of 8
(5,714 Views)
Because they are all the ones found in a different directory than they were originally.
Message 6 of 8
(5,690 Views)
But I didn't touch their directory..I only installed the drivers for the instruments and it shows like they are affected when I open one of them.
Message 7 of 8
(5,640 Views)
Accepted by ma994
That is the fault of the developer.  Just save your VIs and be done with it.
Message 8 of 8
(5,635 Views)
