dequeue element makes lost the sequence
Hello developers!
I want to use the dequeue element function to create and save my data contained in 5 arrays [1x1024] as .raw files.
To do that, part of the solution is in in the attached file but for my surprise the sequence stops after the dequeue element block.
Interestingly I run the example code given in https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/dequeue-element.html and this example code runs perfect even If I implement this simple code drawn in the .png figure inside this example file also works fine but NOT in my project.
Now I am thinking I should setup or configure something in my project but I have no idea what to do or what the problem is...
Can anybody help me with this?
Thanks in advance!
(2,927 Views)
Accepted by topic author nodkry
Hi nodkry,
"for my surprise the sequence stops"
1) You shouldn't be surprised when there is a Stop on Error condition...
2) There is no sequence in your code.
3) Your code never stops on my computer as there is no data source and so the Dequeue waits forever...
(2,918 Views)
That's the thing GerdW thank you!
I was missing the Enqueue element part so I use this in some part of my code and It works fine.
As you can notice I am a beginner in Labview so I am wondering if this solution is good to save a data array of [1X1024] or you can recommend me another option? it seems make a .raw file is not a good solution because I can not read the information :S.
Thanks again for your time and kindness.
 Cheers 😉
(2,883 Views)
