labview no error
Just got done changing a vi and Labview won't let me run it because it says I have errors. However, when I click on the broken run arrow it doesn't list any errors (screenshot attached). It probably has something to do with me fiddling around with shared, global, and local variables which I ended up just deleting because I'm really not a Labview wiz. I tried just copying and pasting the block diagram in a new vi but it pasted as a picture for whatever reason. Any help would be very much appreciated!
(3,618 Views)
I had something similar happen to me recently. Does the VI recover if you do a force recompile by Ctrl-Clicking the Run Arrow?
(3,609 Views)
Unfortunately no =(
Even better, I've attached the vi that acts like a picture and the vi that has an error that it won't show me.
(3,567 Views)
For the one that acts like a picture, I remember seeing a post recently where copying a block diagram from one instance of LabVIEW to another caused this problem (i.e. copying from an instance of LabVIEW 2010 to an instance of LabVIEW 2009).
I don't have IMAQdx on the computer I'm using now so I don't think I'll be able to debug the other VI.
(3,562 Views)
Another Idea:
Have you tried repairing your VAS or VDM installation?
(3,561 Views)
I haven't tried either of those things. I ended up just rebuilding it from a previous version, which was still very inconvenient and a lot of work, but oh well (thank goodness for saving every 10 minutes). Thank you for your help anyway! Kudos for trying
(3,554 Views)
