design control and monitoring system a factory for glass production
Could you please change the version to 19. As I'm currently on my work laptop Revert LabVIEW Files to a Previous Version - NI
Kind regards
LabVIEW Fairy
cRIO Enthusiast
Please mark solutions when appropriate.
Message 11 of 15
(1,093 Views)
This is (19) Version __>
Message 12 of 15
(1,087 Views)
Ah, you are trying to build a model that simulates some aspect of a Factory for Glass Production.  I thought you were actually trying to design the software to actually Control and Monitor a real factory, which requires a lot more than building a (colorful) model.
Before going too far in writing code, take a pencil and paper and write what you want to do.  LabVIEW builds "time" right into the language, so you can (as you've done) make your code run at a "human" speed (rather than "as fast as it can", which is not the way the Real World works!).  Start small -- figure out how to fill and empty one Tank, then think how you might add a second Tank to the mix.  Are they the same size?  Do they fill and empty at the same rate?  What needs to happen if one Tank fills up, or empties?  How do you synchronize/organize multiple Tanks?
Bob Schor
Message 13 of 15
(1,053 Views)
I didn't post the question unless I have tried multiple of times. Because of this, I sent the file so anyone can give a help.
I hope you can see the VI file that I post.
Message 14 of 15
(1,048 Views)
So who made that template of the front panel? Did you get that from the teacher?
You simply need to do things in the right order.
  1. Go over all the class notes from this course. Go over all the learning resources and get familiar with the basics of LabVIEW programming.
  2. Create a simple state machine architecture with one loop and all indicator values in shift registers that are then updated with every iteration. Decide on what all possible states of the simulation are, then update all indicators based on state, time, and user input. Decide on suitable data types for each. (Unless you are dealing with grains of sand, an integer (blue) is probably not correct for any of your tanks!). And no, the loop should never stop until you close the program!
(... and please don't maximize your front panel and diagram to the screen!! That's just annoying!)
Message 15 of 15
(1,018 Views)
