design of multimeter (ADC) using Labview
I want design the analog to digital converter multimeter by using Labview.Anyone of you help me
(4,790 Views)
What version of LabVIEW are you using? What hardware are you using (DAQ board) to input your analog signal?
Take a look at the examples for Hardware Input and Output, or possibly examples that come with your I/O board.
If you can tell us more about what you have, that will help us help you.
B-)
(4,768 Views)
Very good starting point.  Look at code examples.  You can search them from the Labview's Help Menu, under "Find Examples"
(4,763 Views)
Hi Elavarasan
Like the other post already asked there is more information needed to better assist you, Labview version? DAQ card you are using? A multimeter is in essence an analog to digital converter, so what I understand is that you have a DAQ card or are planning on buying one and you want to use it as a multimeter.  In the case you are planning on buying one I will suggest taking a look at this products: Digital Multimeters (DMMs) and LCR Meters.
In the case you already have one DAQ card and you are trying to emulate a multimeter with the card I will strongly recommend reading: Digital Multimeter Measurement Tutorial because there are some specification like resolution, accuracy on others that we need to know to help you build a multimeter.
But let say you want to design a simple multimeter, I would recommend taking a look at our examples, go to labview and click on help>>Find Examples and browse for: hardware input and output>>DAQmx>>Analog Measurement, here you will find examples to read voltage, current and resistance and of our best resources is: Getting Started with NI-DAQmx: Main Page.
I hope it helps
Message Edited by Jaime F on 11-01-2007 05:42 PM
Jaime Hoffiz
Product Expert
(4,736 Views)
