dynamic memory allocation
Hi, guys, does anyone know whether I can use dyanmic memory allocation on the Real time system with "call library function" node. DLL is programmed using C language. Thanks.
Machman
(4,054 Views)
You certainly can. LabVIEW Real-Time functionality is really not much different than what you can do on Windows. The only difference being that you can now assign priorty and timing to your execution loops; essentially, you have determinism with RT whereas with Windows, you never have a guarantee.
Thus, in regards to calling a dll, you can perform this the same way you would in LabVIEW for Windows. Here's a KnowledgeBase article on how to do this if you're not already familiar.
Cheers,
Emilie K. | Applications Engineer | National Instruments
(4,008 Views)
Hi, eek, thanks for your reply.
(3,959 Views)
