designing an encoder sensor using labview
please, can someone help me on how to use  LabView to design encoder sensor. thanks alot
Message 1 of 9
(6,154 Views)
Hi tman,
what do you want to "design"? The color schema of the sensor housing?
Please be more specific with your questions! (And keep in mind this is a forum dedicated to programming using LabVIEW.)
Message 2 of 9
(6,145 Views)
an encoder sensor can be used to measure angular position using QNET mechkit trainer and encoder virtual instrument. Am thinking if i can use Labview to program/design an encoder sensor.
Message 3 of 9
(6,133 Views)
Accepted by tman
Hi tman,
They can also be used to detect linear movements…
Ah, now we are getting closer!
Surely you can use LabVIEW to create a program which detects/analyses the encoder signals! (You don't design the sensor, but the analysis routine!)
I guess by searching for terms like "counters", "AB encoders" you will find ready-to-use solutions. LabVIEW even comes with exampleVIs and probably even there you will find examples…
(I guess this is homework so I will not provide solutions. Do the work on your own and earn your grade!)
Message 4 of 9
(6,128 Views)
in fact, you get me right, i really appreciate that. but kindly link me to where i can get ''counters", "AB encoders" to find the ready-to-use solutions. please. thanks
Message 5 of 9
(6,121 Views)
Accepted by tman
Hi tman,
open the example finder in LabVIEW and look for "counters" in the DAQmx sub-tree…
Message 6 of 9
(6,116 Views)
well appreciated
Message 7 of 9
(6,111 Views)
even though, i can find the encoder theory on the example finder on the labview, but i thought i will be able to get the video also. (the video of already made encoder). and if you get the video, i will love to have it. am new to labview generally. thanks
Message 8 of 9
(6,095 Views)
Accepted by tman
A quadrature encoder? https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1riCAA&l=en-US
=== Engineer Ambiguously ===
Message 9 of 9
(6,089 Views)
