designing an encoder sensor using labview
please, can someone help me on how to use  LabView to design encoder sensor. thanks alot
Message 1 of 9
(6,153 Views)
Hi tman,
what do you want to "design"? The color schema of the sensor housing?
Please be more specific with your questions! (And keep in mind this is a forum dedicated to programming using LabVIEW.)
Message 2 of 9
(6,144 Views)
an encoder sensor can be used to measure angular position using QNET mechkit trainer and encoder virtual instrument. Am thinking if i can use Labview to program/design an encoder sensor.
Message 3 of 9
(6,132 Views)
Accepted by topic author tman
Hi tman,
They can also be used to detect linear movements…
Ah, now we are getting closer!
Surely you can use LabVIEW to create a program which detects/analyses the encoder signals! (You don't design the sensor, but the analysis routine!)
I guess by searching for terms like "counters", "AB encoders" you will find ready-to-use solutions. LabVIEW even comes with exampleVIs and probably even there you will find examples…
(I guess this is homework so I will not provide solutions. Do the work on your own and earn your grade!)
Message 4 of 9
(6,127 Views)
in fact, you get me right, i really appreciate that. but kindly link me to where i can get ''counters", "AB encoders" to find the ready-to-use solutions. please. thanks
Message 5 of 9
(6,120 Views)
Hi tman,
open the example finder in LabVIEW and look for "counters" in the DAQmx sub-tree…
Message 6 of 9
(6,115 Views)
well appreciated
Message 7 of 9
(6,110 Views)
even though, i can find the encoder theory on the example finder on the labview, but i thought i will be able to get the video also. (the video of already made encoder). and if you get the video, i will love to have it. am new to labview generally. thanks
Message 8 of 9
(6,094 Views)
A quadrature encoder? https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x1riCAA&l=en-US
=== Engineer Ambiguously ===
Message 9 of 9
(6,088 Views)
