destructive and non-destructive buffer reads on branch wires
I was asked this morning what are "Destructive and non-destructive buffer reads on branched wires" are.
I was at a loss at first and the I thought some and read a posting by Jim that inspried me.
My first thought was the case of an array wired to a replace array element and an index array function. I that case the the index has to execute before the replace array element because the replace re-uses its input buffer. Not really detructive but seemed close.
There is also the case of a buffer (like a string) being wired into a CIN and the same buffer being re-used be the CIN to return the result. The CIN "destroys" the original values.
Jim mentioned the concatenate string having to destroy the buffer
s hold the strings that are concantenated and moved to another buffer.
Also when I do a AI read the buffer I read from is destroyed after I read it. Similarly with reading from VISA and the like.
What does the above phrase really mean and are there other examples that I have missed?
Trying to learn something here,
Ben
(2,714 Views)
That phrase may have been describing a combination of factors. Documentation from NI points out that if a wire branches, LabVIEW will try to avoid making a copy of the data, including scheduling (as in your example) read operations on branch A before write operations on branch B if possible. Since branch A doesn't tamper with the data, no copy is necessary.
The author of a CIN or DLL could indeed choose to create his function in such a manner that it uses the same physical buffer in memory for input and output. This is by no means the only way to return values from a function, but it's quite common for efficiency reasons. LabVIEW might even assume that a CIN or DLL always overwrites any buffer passed into it (and may therefore make a copy if a wire branche
s both to a CIN and somewhere else).
So to me, the phrase you cited connotes the G compiler's decision of whether or not a wire branch modifies the data (e.g., string concatenation, removing elements from arrays) or just reads it (e.g., an index or input to a calculation).
(2,714 Views)
Hi UnDees,
Thank you for your reply.
Ben
(2,714 Views)
