detect an event from a subVI
Thank you to everyone for the suggestions. I am starting to understand user events now. I have implemented user create event in the main VI and a generate event in the subVI as per the suggestions here. At the moment I am getting the following error and can't understand why:
Error 1 occurred at Generate User Event in control_v4_ML.vi->mainmenu_v3_ML.vi
Possible reason(s):
LabVIEW:  An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @. ========================= NI-488:  Command requires GPIB Controller to be Controller-In-Charge
I have attached a few photos of my code. The 'create event.png' is the main VI and the 'generate event and error.png' is the subVI. The 'user event out' in the subVI is the event refnum from the 'create event' function output.
Message 11 of 12
(685 Views)
Possible reason(s):
@Labview:  An input parameter is invalid. For example if the input is a path, the path might contain a character not allowed by the OS such as ? or @. ========================= NI-488:  Command requires GPIB Controller to be Controller-In-Charge
Time for my favorite saying:
A picture is worth a thousand words, but a VI is worth a thousand pictures.  If you can show us your VI, we can definitely tell you what's going on.  As it is, it seems you have something hooked up incorrectly.
Bill
CLD
(Mid-Level minion.)
Message 12 of 12
(672 Views)
