detect value change not caused by user interaction
I'm looking for an efficient way to wait on value change of a control or indicator which is not cused by user interaction with a front panel.
Does LabView facilitate a mechanism to detect such value change of a control, indicator or property in terms of events, rather than cycic value checks within a loop which I find sub-optimal.
Particular task I'd like to solve in this fashion is to monitor for a value change of a Control/indicator with an attached Datasocket (connected to OPC) or simply to monitor "Bytes at Port" property of Visa Resource in Serial I/O session.
Robert
(2,663 Views)
Why not try using an event structure. You can then create and event that will be triggered on a value change. This should help. Try looking at the example that ship with LV. Hope this helps.
BJD1613
Lead Test Tools Development Engineer
Philips Respironics
Certified LV Architect / Instructor
(2,657 Views)
To add to what BJD suggests, using an event structure, in order for the event to be fired programatically, the new value has to be written to the control/indicator's Value(Signaling) property node. Simply wiring a value to an indicator will not fire the value change event. A user changing the value manually will fire the event, but to do it programatically, you have to write to the Value(Signaling) property.
- tbob
Inventor of the WORM Global
(2,650 Views)
