Hi. Can I generate, say 100 micro second of low signal and 75 micro seconds of high signal using the 6534 board? It's like generating a square wave of 75% duty cycle. Do you guys know what I mean? This is using Labview Digital vis.
Yes You can write out data and with a clock of 25 usec you can send out 7 datawords with 4 1 and 3 zero values. The net result is a puls as you defined. You should repeat this as long as your signal is needed.
