Can the 6534 DIO Board generate pulse with varying time duration?
Hi.
Can I generate, say 100 micro second of low signal
and 75 micro seconds of high signal using the
6534 board? It's like generating a square wave
of 75% duty cycle. Do you guys know what I mean?
This is using Labview Digital vis.
Thanks in advance.
Van
(2,599 Views)
Yes
You can write out data and with a clock of 25 usec you can send out 7 datawords with 4 1 and 3 zero values.
The net result is a puls as you defined.
You should repeat this as long as your signal is needed.
greetings from the Netherlands
(2,596 Views)
Thank you Albert.
I will try this.
Van
(2,586 Views)
