dialog box : write file name
Hello every Body,
I want to show a dialog box wich ask user to write file name before being saved with that name. (See attachement plz)
Thanks to ALL,
(2,889 Views)
You create a vi with the Text control and a boolean (as you have given) and customize the property to hide the close button and make it as a modal vi then your Dialog box is ready. To be simple you can use the "Prompt user input" Express vi for the operation.
(2,887 Views)
Thank you very much for your replay,
I will be very thankful if you can post an exempe for this.
Cordially
(2,883 Views)
Accepted by za3im_ensa
Its very simple try this.
Good Luck
(2,873 Views)
it works, Thank you very much
(2,864 Views)
