dialog box : write file name
Hello every Body,
I want to show a dialog box wich ask user to write file name before being saved with that name. (See attachement plz)
Thanks to ALL,
(3,336 Views)
You create a vi with the Text control and a boolean (as you have given) and customize the property to hide the close button and make it as a modal vi then your Dialog box is ready. To be simple you can use the "Prompt user input" Express vi for the operation.
(3,334 Views)
Thank you very much for your replay,
I will be very thankful if you can post an exempe for this.
Cordially
(3,330 Views)
Accepted by topic author za3im_ensa
Its very simple try this.
Good Luck
(3,320 Views)
it works, Thank you very much
(3,311 Views)
