dialog in parallel
Is it possible to run a dialog, change a control, and update an indicator simultaneously ?  In the example code I would like to be able to change the control values and update the indicator while the dialog is open.  When I select OK from the dialog both loops should terminate.
(3,591 Views)
Could you reupload it in 2012 or even better in 2011?
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
(3,565 Views)
Accepted by ggress1
Please download the code and let me know wheather it helps or not.
(3,554 Views)
Thanks, this helps.  I thought maybe it could be done with a one button dialog.and some looping technique.
(3,531 Views)
