different front panel depending on case structure
I have a VI with a 2 option case structure(true/false boolean). I am wondering if there is a way to have different controls showing on the front panel depending on if my boolean for this case structure is set to true vs false. Each option of the case structure has its own controls and indicators that the other doesn't need.
(5,005 Views)
Accepted by ENGRLAB
You could use a tab control to group the two FPs.
Use a "boolean to 0 1"  to choose which tab to show. You can hide the tabs so nobody will evr know.
Ben
(5,002 Views)
Thanks! This will be perfect
(4,972 Views)
I have the same situation.  Except I have ~12 different case structures with different front panels.  Some with plots/charts/etc.   Will this eventually slow down the execution of the VI with all these tabs running in the bacground?
I guess alot of these charts/plots won't be updated as their controls will only be used during their respective case structure frame.   I guess I won't know until i try...
(4,821 Views)
Hi there,
As long as the code isn't being told to execute simultaneously, you shouldn't be running much of a problem.  Please let us know how it works out for you.
Jon S
Applications Engineer
(4,798 Views)
A slightly more advanced alternative is to use a Sub-panel instead. Depending on what/how the program does it can be a better choice.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,782 Views)
