digital data reception
can i go for
PCI-6533 (DIO-32HS)...
Message 11 of 13
(686 Views)
Hi Ravi,
If you look at the specs for the PCI-6533, it only has a 2Mbits/sec maximum data rate. I would suggest going for either the PCI-6534 or even better a PCIe-6536 (if you have an available PCIe slot). With either of those cards, you will get the data rate you require.
Rohan B
Message 12 of 13
(648 Views)
Thank You BROhan..
Message 13 of 13
(634 Views)
