digital data reception
hi i am characterizing the TLV1572 ADC. It is a 10bit serial ADC. I want to recieve the output of this ADC using the LABVIEW.Also i am using PCI6251 card and scb68 connector. Ho can i proceed..
Message 1 of 13
(4,656 Views)
I asume you intend to connect ADC output to a digital input of your PCI6251...I suggest you have a look at some LabVIEW examples that will show you how you can perform digital measurements (Help > Find examples...and then you can navigate to Hardware Input and Output > Digital Measurements > Cont Read Dig Chan-Int Clk.vi)
Just have a look at those examples and tell us wether or not it answers your problem.
Best,
J.
Message 2 of 13
(4,646 Views)
Hi ravi,
  Just for my information,why dont you connect your analog signal directly to the analog input of PCI 6251...?
Thanks and regards,
srikrishnaNF
Srikrishna
Message 3 of 13
(4,635 Views)
"i am characterizing the TLV1572 ADC"
Kind of hard to test the device if you bypass it.
Message 4 of 13
(4,626 Views)
TLV1572 is generating digital pulses serially at the baud rate of 1.25MSPS so can i have the code in labview which acquires this serial data...
Message 5 of 13
(4,612 Views)
Hi Ravi,
The PCI-6251 is capable of DIO at up to 10MHz.  If the TLV1572 is sampling at 1.25 MSPS with 10 bits of resolution then it will be producing 10.25 Mbits/second of data which is more than could be transfered serially on a DIO line clocked at 10MHz.
Barron
Applications Engineering
Message 6 of 13
(4,593 Views)
Hi Barron you have sent the following message to my friend Ravi.It will be helpful if you please tell me the steps to calculate that for 1.25MSPS with 10 bits resolution the digital data is produced at 10.25Mbits/sec
Hi Ravi,
Barron
Message 7 of 13
(4,546 Views)
1.25MSPS x 10
A single sample is 10 bits, correct? It's a serial output, correct? Each one of those bits has to clocked out before another sample is taken, correct?
p.s. You might want to change your user name to avoid getting spam to your email account.
Message 8 of 13
(4,525 Views)
yes.. you are correct...
Message 9 of 13
(4,500 Views)
hi barron
   then what you suggest .for this ic, which card should i use.?
Message 10 of 13
(4,482 Views)
