digital output 5V and current?
I have a NI 6025E DAQ card. It's digital TTL output signal is 5V. How much current does the output have?
Message 1 of 9
(5,514 Views)
You can get the spec here.
http://www.ni.com/pdf/products/us/4daqsc202-204_ETC_212-213.pdf
According to that,
Port 0 High level Iout = 24mA, Low level Iout = -13mA
Port 1 to 3 High level Iout = 2.5mA, Low level Iout = -2.5mA
Hope that helps.
Message 2 of 9
(5,511 Views)
Anyone knows how much current does pin 41 (1-source) of the 6025E card output? I hope it is at least 20 mA as I want to drive a TIP41 transistor.
Message 3 of 9
(5,459 Views)
I am using a TTL signal to swtich on/Off a TIP41 transistor. Would the TTL signal from PIN-41 (1-source) be enough?
Message 4 of 9
(5,445 Views)
I think the sourcing current is 13mA. It would be a good idea to use a buffer and drive your transistor. Also, consider using a circuit protection for current overlimit to protect your DAQ.
Kudos are the best way to say thanks 🙂
Message 5 of 9
(5,443 Views)
Thanks, I am looking at 6025E manual to confirm that it is 13mA but I cannot find the relevant page. Can you guide? Anyway pin 41 (1-source) is a TTL signnal. Should not a TTL signal be 2.5mA?
Message 6 of 9
(5,437 Views)
The counters are TTL signals, so it should be 16mA high.  Take a look at the following KB
http://digital.ni.com/public.nsf/websearch/ACB4BD7550C4374C86256BFB0067A4BD?OpenDocument
-Jeff P
Message 7 of 9
(5,407 Views)
hi there i found this document : http://digital.ni.com/manuals.nsf/websearch/91DE6638D38E621A862570CF006F23D1 see Page 2 for PFI 3/CTR1 SOURCE It says 3.5 mA only. Is there a contradiction?
Message 8 of 9
(5,391 Views)
Good catch LabVIEW.  I looked into this deeper, because I was befuddled also.  However, what I failed to realize is that family of cards is TTL IN, but CMOS OUT.  Therefore, the specification is right that 3.5 mA.  The KB I linked is right for TTL lines, but inaccurate for the output functionalities of this board.
Sorry for the confusion! Smiley Sad
3.5 mA is correct!
Message 9 of 9
(5,375 Views)
