digital trigger
I have made this program to choose the digital trigger automatically. But now I don´t know how to conncet it in my program.
The purpose of this program is that instead be choosing the trigger you need, the program detects whether there is a letter "A" and if there is, automatically branded.
Message 1 of 9
(4,983 Views)
Hi 99,
This VI can be simplified like this:
(Still error checking is missing, like "input string does not contain any char A".)
This VI has a string input and a boolean 1D array output: these are the possible connections. Why don't you know "how to connect in your program"?
What do you mean by "automatically branded"?
Message 2 of 9
(4,970 Views)
Hi GerdW,
You are right like this the VI is more simple.
Now, I would like to detect the position of the array where is detected the letter "A" and according to that, send a frame in a string.
Thank you
Message 3 of 9
(4,958 Views)
I have one array od booleans and I have detected which position is True. But now I want to send  a frame depending this position that I have detected. I mean if the position 3 is TRUE, I want to send one string which says " position number 3 "
Message 4 of 9
(4,967 Views)
Message 5 of 9
(4,952 Views)
Hi 99,
you already know the "position where the letter A" is detected…
What is a "frame in a string"?
Message 6 of 9
(4,934 Views)
Accepted by labview99
Something like this?:
Perhaps a +1 for the number depending on if you want 0 or 1 as first position.
Certified LabVIEW Architect
Message 7 of 9
(4,935 Views)
Hi 99,
why don't you keep related problems in one thread?
From your older thread you already know the requested position!
Message 8 of 9
(4,931 Views)
Now it goes perfect!! Thank you so much for your help!!!
Best regards
Message 9 of 9
(4,917 Views)
