discontinued timestamp in graph
I have plotted my experiment record with timestamps.  I am happy so far.  But recently, we have a power outage over weekend, so I lost two day's data.  When I link my data together, it simply shift my data two days forward, regarding Monday's data as previous Satureday's.  What should I do?
(2,644 Views)
Hi shan,
maybe you should check your timestamps?
When they are correct and you correctly use them for plotting the data you shoul dget a gap between Friday and Monday...
To solve this question you should apply both VI and (piece) of data log!
(2,642 Views)
Hi GerdW,
Thank you.  I did not make myself clear at the first place.  It is not real timestamp, it is instead a column of Date-Time string.  Please see the attachment, where 13th and 14th August data were missing.  How should I plot?
(2,639 Views)
Hi shan,
it should work like that:
Parse the timestrings, and use an XY-graph for plotting...
(2,631 Views)
