display 1d array in numeric indicator
i would like to display the first element in the numeric indicator, and the next second, display the second element in the numeric indicator and so on.
how do i come around doing tat?
Message 1 of 11
(10,826 Views)
What you want is index array. One more simple way is read the file and pass the array into a for loop and keep the numeric indicator inside and wire it.
good luck
Message 2 of 11
(10,809 Views)
the loop only runs 3 times. y is tat so?
and the first result for indicator 1 and indicator 2 is 12, but in text is suppose to be 0
Message 3 of 11
(10,805 Views)
i did this way - refer to attached VI*
Message 4 of 11
(10,800 Views)
Accepted by topic author wali123
Try this:
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 5 of 11
(10,792 Views)
I believe you have to set the transpose terminal to True in the Read from spreadsheet file vi.
Message 6 of 11
(10,765 Views)
Capture.PNGwhere can i get this icon in the pallette?
Message 7 of 11
(10,746 Views)
Its okay, found it 🙂 im gonna go try the program now.
Message 8 of 11
(10,745 Views)
The result that i get, the date displayed in the front panel is not the same as the date in my text file.
and the values of my wind speed and gust speed is not displayed in the numeric indicators. is it because they are decimals?
Message 9 of 11
(10,744 Views)
You don't have any date information in your text file.  Just a time.  So when you show the date/time in an indicator, LabVIEW will assume it is the 0th day which is Jan 1, 1904.  Exactly what you are seeing in your indicator.
The first several rows of your text file have 0 data.  It isn't until the 8th row that has any data with a decimal value.  Your front panel arrays are only showing the first three.  When I run your VI, the decimals show up just fine for me when it gets to be able to show that data row.
Message 10 of 11
(10,739 Views)
