display data string as text list
Hi all,
How to display data line by line? refer to attachment jpg
thanks,
simon
Message 1 of 10
(4,628 Views)
Hi simon76,
add a carriage return after each line.
Mike
Message 2 of 10
(4,627 Views)
Hi mike,
i try already, but it only display the last string..."disconnect..Operation completed successfully"..all the previous data display been overwrite, so how do i keep all the data as show..
Message 3 of 10
(4,624 Views)
Hi simon76,
you have to write the new and the old data to your control. See the attached example.
Mike
Message 4 of 10
(4,615 Views)
thanks.. get it
Message 5 of 10
(4,611 Views)
Hi MikeS81,
another question here: Is it possible to do as refer to pic1 attach??
Do I need to configure something??
thanks alot and sorry to trouble again.
regards,
Simon
Message 6 of 10
(4,594 Views)
Hi simon76,
no problem. It is possible. What do you want to do with it?
Mike
Message 7 of 10
(4,592 Views)
refer to pic1, how do i configure it?? when first run the test, it show the main vi and when press either the config or test button, another main scrin pop out and the previous scrin disappear. After press the pop up main scrin end button, the original one come  back... so can show me any link or help??
Message 8 of 10
(4,586 Views)
Hi simon76,
here is one solution for it. Another way is to create all vis first, and change only the visible state.
Mike
Message 9 of 10
(4,581 Views)
thank you very much.. i get it..
Message 10 of 10
(4,578 Views)
