display multiple .wav files on same graph
Hi, I am using the sound& vibration toolkit for my project. I am stuck perhaps on something very small!!!!
I am trying to open and display multiple .wav files but i haven't been successful with this. There is already an example which shows how to display one .wav file on a graph. My final goal is to run several .wav files and  do fft of each and display all resultant on same graph. Can someone help me out here. All i want is to open and read several .wav files.
I have attached the code that reads one .wav file.  I am using labview 7.0 so please help
Message 1 of 8
(4,135 Views)
"signal condition" <x@no.email> wrote in message
news:1144123807979-347317@exchange.ni.com...
> Hi, I am using the sound&amp; vibration toolkit for my project. I am stuck
> files and&nbsp; do fft of each and display all resultant on same graph.
> .wav files.
> I have attached the code that reads one .wav file.&nbsp; I am using
> SVXMPL_WAV Power Spectrum.vi:
> http://forums.ni.com/attachments/ni/170/177488/1/SVXMPL_WAV Power
Spectrum.vi
Use the 'film strip' thing to open each file separately. To display more
than one on a graph you can bundle them together.
Tam
Message 2 of 8
(4,125 Views)
Hi Tam
Are there any examples or something that you have? It wuld be greatley appreciated
Message 3 of 8
(4,124 Views)
An easy way to do this is to use an auto-indexed for loop in LabVIEW to run for as many files as you specify.  Attached is a very basic example to show the concept.  Using this, you should be able to build on the SVXMPL_WAV Power.vi to acheive the desired functionality.
Have a great day!
Message 4 of 8
(4,105 Views)
Hey Travis, can you make the same for me but compatible with labview version 6.1?
Message 5 of 8
(3,916 Views)
Here is a picture of what the VI looks like. You can just use this as a reference to make your VI in LV 6.1:
Hope this helps!
Message Edited by Abhinav T on 06-04-2007 01:01 PM
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
Message 6 of 8
(3,879 Views)
Awesome! Thank you Abhinav, I'll try it out
Message 7 of 8
(3,859 Views)
Actually, is there a way to take this one step further? After display the wav files on a graph,or actually multiple graphs (one for each wave file) might be better to see the individual FFTs and then take the difference (subtract) of the signals. I'll probably just be doing this for two different signals
Message 8 of 8
(3,854 Views)
