displaying a message to user
I am comparing temperatures and want to display a message when the value reaches its set point of 80°C and when the user acknowledges the message, I just want the main VI to keep running. It is just a remainder for us to turn off the heater manually.
I tried to do it with display message to user but I cannot change the value of the control without closing the message.
Is there a way a to do it?
(5,176 Views)
Make a VI to show your dialog and make sure it is set to "Floating", not "Modal".  You will then be able to edit your control while the dialog is open.
GCentral
(5,165 Views)
Accepted by topic author girish_jadhav
Hi girish,
Yes, sure!
Don't use a blocking (modal) dialog to display this message!
Simple solution:
Replace that ExpressVI by a simple string indicator, which displays either your message or an empty string…
Btw. you should avoid comparing float values for equality!
(5,164 Views)
He's definitely right. If your heater temperature goes from 79.997 to 80.001 between loop iterations, that message will never appear. At least replace your equals with a greater or equals node.
Redhawk
Test Engineer at Moog Inc.
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
(5,139 Views)
Hi GerdW,
@GerdW wrote:
Yes, sure!
Thank you for the tip regarding comparison. Since the value we are reading from the sensor is also float type I thought it would be alright.
String indicator works, but unless the user is looking at it (there are several tabs on front panel) there is no way to know if it reached its value or not (there is no cue). That's why I wanted to use display message.
PS: How would you set a VI to floating from modal?
(5,063 Views)
Hi girish,
Then you should not hide that string on one of several tabs! Place the indicator on the frontpanel so the user can see it all the time!
In the VI properties…
(5,060 Views)
