displaying partial turns of a motor in labview
this isn't really a problem with labview but more like i think i need help understanding the logic of this simple program. i am reading a motor's encoder which reads 2000 counts per one full motor turn. i would like to see the position of the motor...where it is, as far as making one complete turn. so i was thinking that i need to divide by 2000, or once its made a complete turn, divide by 2000 but take the remainder and compare it to where it is in one full turn. then i would like to display it on the front panel in a meter or speedometer looking thing...could i use the quotient & remainder function or what?
thanks...
samantha
(2,773 Views)
Sure, Q&R will do just fine. 😄 If you want, you can scale the remainder output so it displays fractional turns (divide by 2000), degrees (multiply by 360/2000), etc.
The attached should get you started
(2,773 Views)
thank you but it doesn't seem to be working for me.....i wired the encoder output from my motor into the input for the Q&R....can you please see attached to see where my logic has gone wrong? thanks...
samantha
(2,753 Views)
Well, multiplying by 2000, followed by a division by 2000 does not do anything! 😮
You simply need to divide the remaider by 20 to get the percentage (Use Q&R again but use the IQ output). See if this makes more sense! 🙂
Message Edited by altenbach on 02-10-2006 11:12 PM
(2,753 Views)
thanks for helping me get the logic.....Robot Happy
(2,732 Views)
