distance between GPS points
I have an application where I am collecting GPS data and all is well, had no problem writing the drivers for gps communication but now I need to calculate displacement between my long and lat readings.  Is there a labview function developed to do this or do I need to figure out the calculations and code it myself.  I am trying to not reinvent the wheel.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(4,578 Views)
There is a vi for the Garmin GPS, here.
Here is an application in the Developper's Zone
You may want to check out this thread
Message Edited by JoeLabView on 06-13-2007 08:48 AM
(4,576 Views)
When you say distance between the points, do you mean the cartesian distance between the points (straight line), or the distance between the two points along the surface of the earth?
Message Edited by Sudhir Gopinath on 06-13-2007 12:37 PM
S G
Certified LabVIEW Architect, Certified TestStand Architect, Certified Professional Instructor
(4,556 Views)
Either will probably do.  The distance is over a relativly short distance all measurments will be taken within a square mile or so, I am traveling 10-20 mph and am logging heading gps and speed every 2 seconds,  I am trying to extrapolate the displacement but have not used GPS for this before.
Paul
Paul Falkenstein
(4,532 Views)
Here is a post where I put some GPS stuff.
(4,511 Views)
