distribution kit LVT 8.0
i would like to create a distribution kit ( executable and run times ) which i could deploy on a pxi target without using Labview an especially  the project manager. To be more accurate, my aim is, fistly, to generate this kit of distribution with my develloper host pc, and secondly,  to deploy it on a rt  target by using a virgin PC (with only run time)
Help me
The game
(2,829 Views)
On your RT target I assume that you installed the LabView RT module.
So automatically you have on the disk of your taget this directory C>NI>StartUp.
You can create your exe on your developpement machine, copy it and past it in the StartUp folder. But you will have to create the ini file to specyfy if your vi is lauch at start up or not.
But I do not understand why you do not fellow the standard procedure to deploy a VI on your target.
When you use this procedure the ini file, the alliases file are automatically create on your target.
Johan G.
NIF
(2,815 Views)
I don't use the classic method, which uses the project manager,  to deploy because it doesn't work (error: failed to deploy without other informations, so it isn't very easy to know why!!!!!!!!) and my aim is to deploy an application WITHOUT using Labview.
the game
(2,793 Views)
