03-28-2013 07:35 AM
I can see the dll in LV project items and files view but not in windows explorer. I really need to move this dll. Thanks in advance.
03-28-2013 09:38 AM
Right-click on the file in Project Explorer and choose "Explore" ... it should open Windows Explorer and show it to you.
If you still can't see it, then you may need to show hidden files.
03-28-2013 10:27 AM
I usually do all the obvious stuff before posting here. Still can't find the dll where LV project says it is. I did a work-around and reinstalled the drivers on the target machine. LV lists 5 driver dlls in "D" drive and none of them show up in explorer. I know these drivers are there because I installed them and can find them in various other locations using Search. LV is lying to me. ![]()
