dll problem with labview 8.2.1
   I have a dll which build by delphi and it work fine in labview 6.1. But when I use labivew 8.2.1 to call the dll it seem not working and not even come out an error. Does any one got any idea for this?  Thank in advance.
(2,704 Views)
It should also work with LV8.x
Are you saying that you are not getting an error message?
Are you using the exact same code from LV6.1?  Or was it modified?
R
(2,690 Views)
Hi Joe,
  Yes, I no getting any error when I run in 8.2.1.
 Here is the code in 6.1
and here is for 8.2.1
both run with no error but 6.1 I can communication with my device and get Handel number but 8.2.1 I can't communication with my device. Thank
(2,665 Views)
That is strange....  it should work....
So it does not return a handle.....  Humm...  Not sure what to suggest.  Your screen captures show the same settings.
R
(2,658 Views)
