Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
dll problem with labview 8.2.1
ctk
Member
07-25-2008
08:55 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I have a dll which build by delphi and it work fine in labview 6.1. But when I use labivew 8.2.1 to call the dll it seem not working and not even come out an error. Does any one got any idea for this? Thank in advance.
0
Kudos
Message
1
of 4
(2,703 Views)
Reply
Re: dll problem with labview 8.2.1
Ray.R
Knight of NI
07-26-2008
08:05 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
It should also work with LV8.x
Are you saying that you are not getting an error message?
Are you using the exact same code from LV6.1? Or was it modified?
R
0
Kudos
Message
2
of 4
(2,689 Views)
Reply
ctk
Member
Author
07-27-2008
05:21 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hi Joe,
Yes, I no getting any error when I run in 8.2.1.
Here is the code in 6.1
and here is for 8.2.1
both run with no error but 6.1 I can communication with my device and get Handel number but 8.2.1 I can't communication with my device. Thank
0
Kudos
Message
3
of 4
(2,664 Views)
Reply
Ray.R
Knight of NI
07-27-2008
09:03 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
That is strange.... it should work....
So it does not return a handle..... Humm... Not sure what to suggest. Your screen captures show the same settings.
R
0
Kudos
Message
4
of 4
(2,657 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
