do I have to uninstall Labview 5.1 to install 6.1
thanks
(2,806 Views)
I do not think you have to do so.
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(2,806 Views)
You can have two versions on at the same time. Therefore, you can install LabVIEW 6.1 without uninstalling LabVIEW 5.1. However, if you are building DAQ applications, you want to make sure you have the compatibility VIs for LabVIEW and DAQ for both versions.
J.R. Allen
(2,806 Views)
Its possible to have 5.1 and 6.1 at the same time.
Labview code written in one version might not be executalbe in other versions.I have had problems with instrument drivers when upgrading.
(2,806 Views)
