do i have the buffer in the right place
Personally, I think it's s bad design to request a sample count that is greater than the samples per second. I would put the read inside a loop. With such a high number of samples, your gui becomes unresponsive. Try it and see if the error goes away.
Message 11 of 30
(1,047 Views)
oh so you would need to multiply your timeout by the sample rate to get the exact number of samples you need before it times out.
Message 12 of 30
(1,045 Views)
No. The default timeout is fine. The default buffer is fine.
Message 13 of 30
(1,043 Views)
right now i am getting a million samples but i only need 324000.
Message 14 of 30
(1,040 Views)
Another problem with your arithmetic?
Message 15 of 30
(1,032 Views)
im just not sure what im doing.
Message 16 of 30
(1,028 Views)
I'm totally unsure of what you are doing now. Can you attach an image of your block diagram?
Message 17 of 30
(1,022 Views)
how do you do that.
Message 18 of 30
(1,019 Views)
heres the file im trying to run.
Message 19 of 30
(1,015 Views)
Ok, let's take a step back.
What exactly are you trying to do with this VI?  There is a lot happening on your VI that likely just doesn't need to be there and it will help things A LOT if we do some cleaning up.
Message 20 of 30
(1,008 Views)
