double subtract issue
Hi everyone
0,3-0,2=0,1 ???
Why does Labview turn false result?
Himmet GENCER
Software Development Coordinator at TDG
himmetgencer@gmail.com
View Himmet Gencer's profile on LinkedIn
View on Instagram
(3,305 Views)
Because precise conversion between decimal fractions (human way) and binary fractions (machine way) is not always possible.
Consider this: in decimal 0,3 = 3/10
                     in binary 0,3 = 1/4 + 1/32 +1/64 + .... and you cannot add it up to exactly 0,3.
So, to summarize, when comparing the results of a double arithmetics to some other double, you must never use '=' to compare to an exact constant. What you need to do, is check if the result falls into a certain range - depending on your needs.
Br, Miha
(3,297 Views)
Thanks Miha...
Himmet GENCER
View on Instagram
(3,291 Views)
You are running into a well-known situations occurring within all programming language. It's all about numeric respresentation on a digital system (so you will have "quantized values").
There are already a dozens of threads about this (e.g. this one) so please use the search function of this forum.
thanks,
Norbert
EDIT: Make it a rule: Never use a simple "equal" comparison on floating point values. Always compare to a range of values!
Norbert
Expert: Geometry
(3,280 Views)
To understand the problem you'll need to understand how Float works and is represented.
Since all numbers are stored in binary format there's no 0.1(decimal), it gets translated to 1/16+1/32+1/256 and so on (similar to 0.00011001... bimals(?))
So, simply put, 0.2-0.1 in decimal doesn't turn out to be as nice answer when looking at binary, thus the comparison with 0.1 doesn't work.
0.5-0.25 will work fine ...
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,274 Views)
Someone owes S-mercurio another nickel for his retirement fund.
(3,238 Views)
I was just going to say that! Smiley Wink
(3,236 Views)
