double to single precision on a formula node
hi,
i am working on LV and using formula node structures. In order to save memory, i have to use single precision numbers. When i am using formula node, even if my inputs are single precisions, my outputs are double precision number. How can i change it?
thanks
gaetan
(4,352 Views)
Hi Gaetan,
All you need to do is declare the outputs as "float32" this should give you single precision outputs.
Hope this helps,
Nick
(4,352 Views)
Hi Gaetan,
What you need to do is declare your output as a float32 like in the picture attached.
See in the knowledge base for more info : http://search.ni.com/query.html?col=alldocs&ht=0&qp=%2Bcontenttype%3Aknowledgebase+%2Blanguage%3Aenglish&qs=&qc=&pw=575&ws=0&la=en&si=0&fs=&qt=formula+nodes&ex=&rq=0&oq=&qm=0&ql=&st=11&nh=10&lk=1&rf=0&layout=KB
Hope this helps !
Julien
(4,352 Views)
