double y-axis waveform graph: How change axis label programatically
Im using the waveform graph to show data from experiments. The user can select channels to display; I've made 2 y axis to display 2 channels.
I would like the y-axis label to change for different channels. With an XY-graph I did this through a property node, but I cant find them for the separate y-axis for the
waveform graph.
how to achieve?
thanks
(3,569 Views)
Accepted by topic author _Faust
Are you setting the Active Y scale first?
Post an image of your code so we can look over your shoulder and comment.
Ben
(3,567 Views)
That was the solution THANKS! I didnt even know what that property was for. I used it to switch from 0 to 1 (other axis).
(3,555 Views)
