IviDCPwr Configue OVP.vi does not work when enabled is set to true.
There is an IviDCPwr [MSR] - Output DC Volts.vi example in Labview 2009. There is IviDCPw Configure OVP.vi which is used for enabling or disabling the OVP limit feature. I have tested this VI with E3631A this power supply does not support OVP enable so this parameter is set to false and the VI works fine.
When testing with N5749A, this parameter needs to be true since this power supply does not support OVP disable. There is an error being generated with this VI. If I remove this VI , the default limit value is 100 and the VI is working fine and setting the current and voltage without any issue.
Could anyone let me know if they have faced any similar problem and how it can be solved.
Best Regards
Anshul
(2,594 Views)
Hello Anshul,
       Can you please post more information about the error that is being generated?  Also, please see if the problem appears when the N5749A IVI Specific driver is in simulation mode.
Cheers,
NathanT
(2,572 Views)
