drawing a guage
Hi
I am doing a project where I should control the rotary meter, so my users require me to show the position of the rotary with a guage. so i want to know how can I show the guage with a thicker needles. I want to have two needles with a label on them( e.g needle1) and the needles should be able to rotate as the rotary meter rotate. I tried to draw it but it does not work at all.
Please help
Message 1 of 13
(4,879 Views)
Hi netee,
right click on your gauge (in the Front Panel) and select "add needle".
see the attached example.
Mike
Message Edited by MikeS81 on 03-28-2008 10:46 AM
Message 2 of 13
(4,878 Views)
Thanks for the example. I did show them the similar picture but they say they want a picture with thicker needles. The needle should  even be thicker at the tip of the needle and be able to number those needles so that they can clearly know which needle is in what position.
Thanks!
Message 3 of 13
(4,866 Views)
Hi netee,
you can change the color of the needles.
Mike
Message 4 of 13
(4,863 Views)
Thanks! the problem is there are the rotaries which have got to be represnted with six needles so it is going to end up being confusing for using six different colours. Is there another alternative?
Message 5 of 13
(4,859 Views)
Hi netee,
you can use something like this, or one gauge for every needle.
Mike
Message 6 of 13
(4,855 Views)
Thank you. The example is gonna help but I want to know if there is a way of defining the shape of my needle(e.g the thickeness or structure) because the users want something that can duplicate the system they have.
Thanks!
Message 7 of 13
(4,842 Views)
You can replace the needle with an arrow from the decorations palette (see tst's Nugget on customize guages).
Otherwise you can use the Picture Control to render the needle as required.
Ben
Message Edited by Ben on 03-28-2008 08:46 AM
Message 8 of 13
(4,828 Views)
I don't think it's possible to make the needles thicker. I've even tried to customize the gauge. In customize you can select a needle then import a picture from file (say, an image of a "fat" needle) but the image just orbits around the axis. It looks pretty stupid. Smiley Very Happy Customizing controls in LV is still very rudimentary at best and a waste of time.
PaulG.
Retired
Message 9 of 13
(4,820 Views)
This is just to illustrate that tst's technique of using the decorations to replace the needle does rotate.
But I agree with Paul that if this technique is not good enough, rendering the needle in a picture control is the only option.
Ben
Message Edited by Ben on 03-28-2008 09:05 AM
Message 10 of 13
(4,812 Views)
