driver compatibility problem
I am using is LV2017.
Due to driver download issues from ni.com, I downloaded the LV2021 version.
Is there a way to view the 2017 version?
thank you
(1,889 Views)
Hi minseob,
on NI.com/idnet I also found drivers for K26xx provided for LV2015.
Why don't you download them and use them with your LV2017 installation?
(1,853 Views)
Thank you for the reply.
The driver for LV2015 from NI.com/idnet is unavailable due to a 404 Not Found error.
How should I resolve these cases?
(1,821 Views)
Accepted by minseob0530
You should contact NI technical support and report this issue on the missing file.
Meanwhile, I have downgraded the files as attached.
https://tmesystems.net/
(1,793 Views)
