/drivers/daq/setup/ni_rundll or one of its components not foun
I cannot install daq because of this message. Where is the component?
thanks
(2,669 Views)
Thank you for contacting National Instruments.
I may have found a knowledge base entry that accurately addresses your problem. Following these instructions will, hopefully, resolve your Dll problem.
To access the knowledge base entry, please do the following:
1) Go to http://www.ni.com
2) Scroll down and click [KnowledgeBase] under "Technical Support"
3) Click [Search all entries]
4) Search for "daq rundll"
5) Click the first link "Partially Complete NI-DAQ 6.1 Installation Gives Error about a Missing RUNDLL"
6) Follow the on-screen instructions
I hope this helps. Please feel free to notify me if you need more assistance. Have a great day!
Kind Regards,
Joe Des Rosier
(2,669 Views)
I had already tried this, the problem is that the path that autoinstall is looking for is inside the codes on the CD and I cant access that to change it, it does not give a browse option, it is hardwired.
The problem is that ni_rundll exist on the CD in drivers/DAQ/cabs/setup/ but it is listed as ni_run~1 as are several other files.
(2,669 Views)
Are you actually trying to install DAQ, or are you trying to install LabVIEW? What software version(s) are you currently using?
If you're trying to install DAQ, I have a suggestion. Please go to www.ni.com and click [Drivers and Updates] on the left. Click [All software versions}, then scroll down and click [Multifunction DAQ] under "Measurement Hardware." Download the current DAQ driver for your version of LabVIEW and operating system and install the file.
Please let me know if this helps, and feel free to contact me for further support.
Kind Regards,
Joe Des Rosier
(2,669 Views)
