drop down selection in word
Hello, just trying to get a quick solution here for my report.
How can I, with labview, in the attached doc, go to the dropdown table in this doc and make any selection I need. for example we have 4 selection here: Pass, Fail , not applicable and not tested. How don I call the document in Labview and I select the item needed?
Thanks for your quick help.
(3,300 Views)
Accepted by agyna
You actually have 5 selection, the first one is "Choose an item." and what you have is a Content Control located in a Table cell.
This is how you can do this:
Ben64
(3,262 Views)
Perfect. Works fine. Thanks a lot.
(3,250 Views)
