dynamic data to database
Hi, I'm trying to send dynamic data to a database in microsoft access, but I'm having troubles becuase no matter how many points I send it always appears the same number in my database.
I'm new in all this database with labview and I can't figure out how to send all the points of my dinamic signals.
Greetings and thanks!!!
Message 1 of 8
(5,065 Views)
I'm thinking that your problem lies in the fact that you're converting your dynamic data to a single scalar.  The Simulate Signal Express VIs make the same data each time you run them, and you're only taking (the same) one point from all of it.
Jim
Message 2 of 8
(5,038 Views)
Thanks for replying jcarmody.
The problem is when I convert the dynamyc signal to an array, the database can´t read it because only accept strings and I don't know how to make my database read that array.
Message 3 of 8
(5,028 Views)
Accepted by Rolando-stc
My first thought was to write each point in a For Loop, like this:
My next thought was to convert the array into a spreadsheet string and store one waveform measurement in one database record.  I expect this would be faster because there's only one SQL INSERT happening.
Jim
Message 4 of 8
(5,022 Views)
thank you so mucho jcarmody, it works perfectly 🙂
Message 5 of 8
(4,995 Views)
You're welcome.  Which one?
Jim
Message 6 of 8
(4,987 Views)
the first one because the second one also gave me all the values but in a single cell
Message 7 of 8
(4,972 Views)
You should be able to modify JC's first to build 1 query instead of inserting line by line, assuming the total isn't too long. You can also simplify it slightly by using the Insert-vi.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 8
(4,961 Views)
