easy question - scroll bar position in listbox problem
Accepted by gigi85
If this property is avialable in LV 7
Message 11 of 13
(1,008 Views)
Hi, gigi85,
Multicolumn list box also has some thing similar, but its Top Left visible parameter.
Just create new vi and try the same using property nodes and try posting vi.
In the front panel, did u enable the vertical scrollbar (just checking, still it shouldn't be a problem u shud see the property node in block diagram)
I see from KC's post, that even 7.1 has that property( was doubting untill, whether 7.1 had that or not)
uday
Message 12 of 13
(1,004 Views)
thanks to all...with top lef visible cell property box i solved my problem 🙂
Using LabVIEW 7.1
Message 13 of 13
(985 Views)
