ecg
@sanaaa wrote:
any other way?because the uni is not goin to buy a toolkit just for my project:(
Perhaps you can use a 30 day trail version Smiley Very Happy
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 31 of 40
(1,641 Views)
Conductance = 1/resistance.  This is rather easy to program in LV.
Lynn
Message 32 of 40
(1,635 Views)
mhos = 1/ohms
-AK2DM
Message 33 of 40
(1,624 Views)
ya i know conductance=1/resistance.but im not very thorough with labview.how do i program this in labview.
Message 34 of 40
(1,614 Views)
Have you tried using some of these functions. You may use at least two of functions in this palette
Message 35 of 40
(1,611 Views)
ya i know these functions.though never used them.so i use these functions to convert voltage into resistance and finally into conductance?
Message 36 of 40
(1,606 Views)
This is going nowhere. Can you post your code. And code is not a picture.
Message 37 of 40
(1,603 Views)
this is what i have.i am just getting the signal and result is in volatge that is the amplitude
Message 38 of 40
(1,591 Views)
Using Express VIs is like peeing in your pants a cold winter day. You may get warmer for a few minutes. But after that it will be very cold. And just now you have become very cold. Also Labview programming is not just tossing some Express VIs out in a happy-go-lucky style. Then wire it quickly together hoping it will work. You must have some plan or idea of what you are doing, and what you try to achieve. You do some sampling and filtering. This mean you somehow must have data points some place. Let us follow that track. Show some ingenuity, and dare to explore using traditional Labview
I have made a VI which we can use as our workhorse. It is quite simple. I also include some papers regarding Skin conductance. By the way The correct thing is use a constant voltage, then measure the current.
Message 39 of 40
(1,583 Views)
well im quite sure of what im doing.so thnx for your advice.i got my problem solved.i just needed some value to determine the emotions.so i am going to use voltage so i dont need to convert it into anything.
Message 40 of 40
(1,553 Views)
